D2smoke Posted September 21, 2020 Posted September 21, 2020 I needed assistance with matchmaking for over a month me and my 6 friends over the weekend like to play elimination on destiny 2 we use the geofilter and 2 systems connected to the same xr500 the last 48 hours we are not able to matchmake with each other anymore? We changed nothing on the router except trying to activate the vpn that is when the issues really started. Can anybody help me here please!? Over a month weve never had a problem matchmaking each other upĀ 9/20/20 now its 1 match we connect and then a bunch of randoms
Administrators Netduma Fraser Posted September 22, 2020 Administrators Posted September 22, 2020 The Geo-Filter is not designed to allow you to matchmake with another console on your home network so that you can play against each other. We haven't changed anything on our end so it will be Destiny. We need to make some actual changes to the Geo-Filter for Destiny to help with normal matchmaking but it is unlikely to help with what you're trying to do specifically. It will take time to do this as well as it's not as simple as usual.
