ajkron Posted September 9, 2020 Posted September 9, 2020 woke up this morning and all my smart devices(ring, wyze, echos,etc) were not connected and cannot get going again. also unable to connect to outlook mai app, just get trying to connect. can surf normal on wifi and wired but can not get any of these devices going again on wifi. updated to the latest firmware v2.3.2.56 after the issue with no luck. any help would be greatly appreciated. thanks!
Administrators Netduma Fraser Posted September 10, 2020 Administrators Posted September 10, 2020 Hey, welcome to the forum! Are you using Smart Connect for WiFi? I.e. you have just one WiFi name to connect to? If so I think that will probably the cause, disable this and see if they can connect properly to the 2.4GHz.
