defiled669cfh Posted August 21, 2020 Posted August 21, 2020 my buddy is older and having a hard time finding the firmware update for the 3.0 beta, he has the beta but someone said there was and update anyone got a link to the update
Administrators Netduma Fraser Posted August 22, 2020 Administrators Posted August 22, 2020 If you have access then it can be downloaded from here: https://forum.netduma.com/topic/31792-firmware-download-v30105-adblocker-works/
defiled669cfh Posted August 22, 2020 Author Posted August 22, 2020 one quick question, google sayd my router login is unsafe is there a way to fix that thank you fraser you are the man
Administrators Netduma Fraser Posted August 22, 2020 Administrators Posted August 22, 2020 19 minutes ago, defiled669cfh said: one quick question, google sayd my router login is unsafe is there a way to fix that thank you fraser you are the man It's a local site with no personal information entered onto it so its completely safe to use/access!
