Clint Posted August 20, 2020 Posted August 20, 2020 Hello, I'm new to the forum. I need some advise setting up NetDuma R2 on Asus DSL AC68U. Hope you can help Thanks Clint
Administrators Netduma Fraser Posted August 20, 2020 Administrators Posted August 20, 2020 Hey, welcome to the forum! There probably isn't much you need to do specifically other than: Follow the guide in the box to connect the R2 to your existing modem/router Connect to the interface as per the guide and go through the setup wizard One you've completed the wizard go through the tour it gives you If you have any trouble after that let us know.
Clint Posted August 20, 2020 Author Posted August 20, 2020 Thanks Fraser, I'll let you know how I get on. I presume I'm best to disable WiFi on Asus router? Thanks Clint
Administrators Netduma Fraser Posted August 20, 2020 Administrators Posted August 20, 2020 47 minutes ago, Clint said: Thanks Fraser, I'll let you know how I get on. I presume I'm best to disable WiFi on Asus router? Thanks Clint Yes that is what I would suggest so all devices run through the R2.
