More advanced WiFi settings?
tephra
Hi Guys,
I am wondering if band steering is able to be used on the R2?
What about DFS channels? Or channel width?
What region is the WiFi radio set for?
Thanks in advance!
Regards
D.
The mirror mode produces one SSID that you connect to and it will switch you between 2.4/5GHz.
No DFS at the moment.
Region is set to the country the router was shipped to.
We are working on a firmware at the moment that improves wifi and allows you to change width.
Ok...  I think band steering would be good, lots of devices stick to 2.4ghz..
What about adjusting power levels, or auto channel scanning (to pick free/best channel?)
Yes some more of those options will be available. We'll keep tweaking and implementing in order to get people the best wifi performance possible.
