A5hba5h Posted July 3, 2020 Posted July 3, 2020 I received a new modem from spectrum so after installing it, my R1 stop working. i have my modem connected to the router and from the router to my PC. After I did a hard reset i was finally able to access 192.168.88.1 I've tried playing around with the settings but i still cant get the R1 to broadcast any wifi. Please help
Administrators Netduma Fraser Posted July 4, 2020 Administrators Posted July 4, 2020 Hey, welcome to the forum! Sorry to hear you're having this issue. Go to Settings > WiFi, disable it, apply then reboot. Then go back, enable, apply, reboot. Do you see the WiFi appear properly then?
A5hba5h Posted July 4, 2020 Author Posted July 4, 2020 No unfortunately its still not work. I see the name of the wifi, netduma but it says unable to identify IP. I cant even go on 192.168.88.1
A5hba5h Posted July 4, 2020 Author Posted July 4, 2020 I think there's a problem with the network connection. Any idea where it mite be messed up there ?
Administrators Netduma Fraser Posted July 5, 2020 Administrators Posted July 5, 2020 Have you disabled DHCP by any chance? On your actual device set a static IP: IP: 192.168.88.2 Subnet: 255.255.255.0 Gateway: 192.168.88.1 and then see if you can get a connection and access.
A5hba5h Posted July 5, 2020 Author Posted July 5, 2020 I reset my network settings and another hard reset on the router and after that my pc was Only able to connect to internet. Wifi still doesn't work on any device. When I applied the IP address you gave me, I lose connection entirely. In my network connections, its all bridged. Any other ideas ? Please help
Administrators Netduma Fraser Posted July 6, 2020 Administrators Posted July 6, 2020 When connected via ethernet can you open command prompt and type ipconfig please and press enter, then post the results here.
