Need help with internet
Fashion
So i plug me provider router back in and i see i was getting the download speed i was suppose to get which is 333mbps then i plugged in the NetdumaR1 and got way lower  which is 30mbps is this suppose to happen if not how can i fix this ?
Were both these tests done via ethernet (wired connection)? Are you using the Original R1 Firmware or DumaOS? Either way, have you entered the bandwidth you expect in Bandwidth settings? If OG firmware did you allow it to setup automatically for your speeds? If DumaOS disable QoS completely from the same menu where you enter your speeds and see if you get full speeds then.
yeah im using Qos and yes both were wired  connections  im using Dumaos yes I still entered the bandwidth of what my internet suppose to be
