XR500 Set-up and LAN Issue
My XR500 is connected to the ISP (At&T) modem (BGW210) fiber optic 1000mbps
Set up: I bought this router for my PS4 (Wired) and Modern Warfare and I also have 3 Firesticks streaming Tv (Live Tv) having said all that I would like to know if is any settings that I need to change on the router. I disable the Wifi capabilities of the Modem but that was it;;
Issue: Starting to get an issue that my Internet drops very quickly and I lose my LAN connection on my PS4 (Just started happening)
Latest Logs:
[admin login] from source 2600:1700:1d20:c13f:14d3:b7ce:abd6:4d45, Monday, May 25, 2020 21:48:25
[admin login] from source 2600:1700:1d20:c13f:14d3:b7ce:abd6:4d45, Monday, May 25, 2020 21:47:56
[admin login] from source 2600:1700:1d20:c13f:14d3:b7ce:abd6:4d45, Monday, May 25, 2020 21:47:53
[admin login] from source 2600:1700:1d20:c13f:14d3:b7ce:abd6:4d45, Monday, May 25, 2020 21:47:41
[DumaOS] config write 'com.netdumsoftware.geofilter.settings', Monday, May 25, 2020 21:47:25
[DumaOS] config write 'com.netdumsoftware.geofilter.settings', Monday, May 25, 2020 21:47:24
[admin login] from source 2600:1700:1d20:c13f:14d3:b7ce:abd6:4d45, Monday, May 25, 2020 21:47:24
[DumaOS] config write 'com.netdumsoftware.geofilter.settings', Monday, May 25, 2020 21:47:19
[DumaOS] RPC call 'add_capture' exception 'ERROR: Unable to install because some filters are overlapping. stack traceback: ^I?, in function '__new__' ^I?: in function '?' ^I?: in function <?:469> ^I(tail call): ? ^I?: in function 'add_gf_service' ^I?: in function <?:284> ^I(tail call): ? ^I?: in function <?:324> ^I[C]: in function 'xpcall' ^I?: in function 'try' ^I?: in function <?:290> ^I[C]: in function 'run' ^I?: in function <?:345> ^I[C]: in function 'xpcall' ^I?: in function 'try' ^I?: in function <?:261> ^I(tail call): ? ^I/dumaos/api/cli.lua:48: in function </dumaos/api/cli.lua:30> ^I[C]: in function 'xpcall' ^I/dumaos/api/cli.lua:59: in main chunk ^I[C]: ?' Monday, May 25, 2020 21:47:13
[DumaOS] config write 'com.netdumsoftware.geofilter.settings', Monday, May 25, 2020 21:47:04
[admin login] from source 2600:1700:1d20:c13f:14d3:b7ce:abd6:4d45, Monday, May 25, 2020 21:46:55
[DoS Attack: Ascend Kill] from source: 17.253.6.253, port 123, Monday, May 25, 2020 21:40:08
[DumaOS] DHCP lease change., Monday, May 25, 2020 20:59:01
[DumaOS] DHCP new event., Monday, May 25, 2020 20:59:01
[DHCP IP: 10.0.0.3] to MAC address f4:0f:24:2d:c3:30, Monday, May 25, 2020 20:59:01
[DumaOS] config write 'com.netdumasoftware.devicemanager.database', Monday, May 25, 2020 20:54:58
[DumaOS] DHCP lease change., Monday, May 25, 2020 20:54:57
[DumaOS] DHCP new event., Monday, May 25, 2020 20:54:57
[DHCP IP: 10.0.0.3] to MAC address f4:0f:24:2d:c3:30, Monday, May 25, 2020 20:54:57
[DumaOS] DHCP lease change., Monday, May 25, 2020 20:28:46
[DumaOS] DHCP new event., Monday, May 25, 2020 20:28:46
[DHCP IP: 10.0.0.3] to MAC address f4:0f:24:2d:c3:30, Monday, May 25, 2020 20:28:46
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:26:15
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:25:48
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:25:18
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:24:42
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:24:25
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:23:57
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:23:28
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:23:18
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:23:09
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:22:47
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:22:37
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:22:17
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:22:07
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:21:47
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:21:36
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:21:17
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:21:05
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:20:47
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:20:34
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:20:17
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:20:04
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:19:47
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:19:33
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:19:17
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:19:01
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:18:46
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:18:31
[admin login] from source 2600:1700:1d20:c13f:e46f:f3bf:e1ec:299a, Monday, May 25, 2020 20:17:31
[DumaOS] Cloudsync Themes result 'false','All mirrors are down', Monday, May 25, 2020 20:15:00
[DumaOS] Geo-Filter cloudsync result 'true','Geo-Filter is up to date', Monday, May 25, 2020 20:14:51
[DumaOS] Marking device that is marked 10.0.0.2 14 1., Monday, May 25, 2020 20:14:45
[DumaOS] DHCP lease change., Monday, May 25, 2020 20:14:44
[DumaOS] DHCP new event., Monday, May 25, 2020 20:14:44
[DHCP IP: 10.0.0.2] to MAC address c8:63:f1:81:3c:03, Monday, May 25, 2020 20:14:44
[DumaOS] Error parsing line in ARP table: 'fe80::8aef:16ff:fe9d:37a0 dev brwan lladdr 88:ef:16:9d:37:a0 router REACHABLE', Monday, May 25, 2020 20:14:38
[Time synchronized with NTP server] Monday, May 25, 2020 20:14:35
[Internet connected] IP address: 192.168.1.112, Monday, May 25, 2020 20:14:24
[DoS Attack: TCP/UDP Echo] from source: 17.253.6.253, port 123, Monday, May 25, 2020 19:50:00
[DoS Attack: TCP/UDP Echo] from source: 17.253.20.253, port 123, Monday, May 25, 2020 19:49:58
[DoS Attack: TCP/UDP Echo] from source: 17.253.6.125, port 123, Monday, May 25, 2020 19:49:56
[DoS Attack: TCP/UDP Echo] from source: 17.253.6.253, port 123, Monday, May 25, 2020 19:18:29
[DoS Attack: TCP/UDP Echo] from source: 17.253.6.125, port 123, Monday, May 25, 2020 19:18:27
[DoS Attack: TCP/UDP Echo] from source: 17.253.20.125, port 123, Monday, May 25, 2020 19:18:25
Given your speeds I don't think you'll need to change any QoS settings. On your ISP router have you put the XR in the DMZ? For the PS4 the only thing I can see in the log that might be affecting it is the DHCP Lease so set a reserved IP in LAN Settings and see if that resolves it. Also are you using the Geo-Filter?
I havent put it on DMZ;; yes I am using the Geo Filter. If you can show me how to do the DMZ and DHCP for the PS4 it will be greatly appreciat it;; thanks for even replying to this threat
