aircashtro Posted May 15, 2020 Posted May 15, 2020 jokes aside ive deleted the bottom right pin in the geo filter tab i currently have devices, geo filter map, and allow and deny pins but since i just got my router i dont know which pin im missing can someone help me?
Administrators Netduma Fraser Posted May 16, 2020 Administrators Posted May 16, 2020 Hey, welcome to the forum! That is where the ping panel goes, it will only appear when you either ping a game manually or if you have auto ping enabled and that will show when you're in a game.
aircashtro Posted May 16, 2020 Author Posted May 16, 2020 Thank you, I noticed it later on and pinned it to my dashboard. I appreciate your help!
