XR300 - Slow speed - observation
I recently bought a XR300.
Must say its a bit disappointing 😞
Connecting to the interface sometimes takes long to load and sometimes fails to load. Some uncaught reference errors ..... does not look well tested or rounded off.
Then the slow speed via the router - it just plain sucks, but I have discovered one setting that definitely slows it down, if you switch on setting/monitoring/traffic  meter with a setting of no limit - just to get stats of data usage - the router seems like it is limited to somewhere round 80Mbps ..... turn the setting off - higher speed (still not full speed) - turn it on - reduced speed.
It seems to affect ping as well - adding a couple of ms ....
P.S. I am running the latest firmware on it (1.0.3.38_10.3.30)
Qos is off via the AntiBufferbloat menu, rest is all standard settings
What web browser are you using to access the interface? What speeds do you pay for/expect and what speeds are you actually getting? What is your physical setup? E.g. ISP hub (some devices connected via WiFi) > XR300 (wired and WiFi devices).
