XR300 Autonegociation Problems
Hi
I have a Fiber connection provide by Openip my FAI and Covage
For my connection my provider put me these materials
FIBER LINK =>>RAD - ETX203AX Connected to an OPIOS router connected to the wan port of the XR300
I have a problem of autonegociation for the speed .
By default actually the XR300 see an HalfDuplex and limit my network in download to 20MB and i have 80MB normmaly
How to force this port to a FD ???
Where can i change speed and mode of speed to the wan port in the OS ???
Thanks ..
Is the XR300 using default dynamic/automatic settings in Settings > Internet Setup? On the QoS page in the Anti-Bufferbloat options have you input the speeds that you are supposed to get? In the Device Manager for the WAN port it actually says you're getting half duplex? That's not something you can change on the XR300 you may need to try and find that option on the OPIOS router.
