Hawk62 Posted November 28, 2019 Posted November 28, 2019 Bonjour j'ai un netgear xr300 et je joue a destiny sur ps4 et pc Sur ps4 aucun probleme parcontre sur Pc le jeux prend 5min a ce lancer et sa ne le faisait pas avant d'avoir le router merci d'avance tu coup d'pouce
Administrators Netduma Fraser Posted November 28, 2019 Administrators Posted November 28, 2019 Bonjour, bienvenue sur le forum! Dans le Gestionnaire de périphériques, modifiez votre PC en console Type de périphérique, par exemple. PlayStation, puis rajoutez-le au filtre géo pour voir s'il fonctionne correctement. - Hello, welcome to the forum! In the Device Manager change your PC to a console Device Type e.g. PlayStation and then re-add it to the Geo-Filter and then see if it works correctly.
Hawk62 Posted November 28, 2019 Author Posted November 28, 2019 le geo filtre fonctionne maintenant mais le jeux et toujours long a ce lancer
Administrators Netduma Fraser Posted November 28, 2019 Administrators Posted November 28, 2019 Pourriez-vous clarifier? La traduction n'a pas fonctionné correctement. - Could you clarify? The translation didn't work properly.
Hawk62 Posted November 28, 2019 Author Posted November 28, 2019 geo filter ok now destiny is long for lunch on pc
Administrators Netduma Fraser Posted November 28, 2019 Administrators Posted November 28, 2019 The game takes a long time to launch? If you change the Geo-Filter to Spectating Mode while launching and then switch back when on the game to Filtering mode does that speed it up?
Administrators Netduma Fraser Posted November 28, 2019 Administrators Posted November 28, 2019 Sounds like it's just to do with the game or PC then, thats not something we can resolve.
