blakeyb1 Posted July 11, 2015 Posted July 11, 2015 Hey guys I'm on Virgin media and my superhub connected straight to my PC is 120mbps but when I connected to the Netduma with reactive I get 70mbps at the best which is strange cause it seems my settings are fine. What's up can an admin take a look at my router?
Netduma Staff Netduma Crossy Posted July 11, 2015 Netduma Staff Posted July 11, 2015 Could you go through the instructions here and see if they increase the speeds please Make sure you test with congestion control sliders at 100%.
blakeyb1 Posted July 11, 2015 Author Posted July 11, 2015 Could you go through the instructions here and see if they increase the speeds please Make sure you test with congestion control sliders at 100%. The deep packet processing thing worked thanks, what does that do anyway?
Netduma Staff Netduma Crossy Posted July 11, 2015 Netduma Staff Posted July 11, 2015 The deep packet processing thing worked thanks, what does that do anyway? It is used for the PC analytics and for the VPN hybrid when a source game is set as an exclusion from the VPN As the problem is sorted I'll close the thread - please feel free to make a new one with any more problem/questions.
