CALL LOGIN AFTER UPGRADING TO DUMA OS ON NETDUMAR1!!HELP P,EASE
Hey guys. My Netudma R1 is actually not allowing me to get into the router. Although it can still detect and provide internet when connected with the LAN cable. After upgrading my normal R1 os to duma os, my route3r is not allowing me in the router even after correct credentials. As I didn't have any type Of login credentials earlier, so for logging into the duma OS has to be the default, Right? ID-admin, Password-password. But guys it doesn't work even after several times of tries. Moreover, my Hard Reset button at the back of my Netduma is also kinda broken and doesn't work. What should i do now? Its probably the fault of the dams DUMA OS though or something else with the os for sure.
THANKS
Are you using the default router IP address? What Gateway IP is listed on your devices? Perhaps you changed the default IP on the old version and the upgrade put it back to normal?
