Dopam-IT_1987 Posted January 2, 2019 Posted January 2, 2019 bonjour à tous, j'ai l'impression d'etre en retard depuis quelques temps sur tous les jeux, je ne me teleporte pas ou bug du genre, mais je vois pas l'amelioration avant apres dumaOS, j'ai suivi le guide à la lettre mais rien y fait ,j'ai aussi ma bande passante passante qui se réduit de moitié ... merci
Administrators Netduma Fraser Posted January 2, 2019 Administrators Posted January 2, 2019 Those settings look fine but what about the rest of QoS and whats your average ping to the game as shown by the Geo-Filter?
Dopam-IT_1987 Posted January 15, 2019 Author Posted January 15, 2019 Bonjour chive972, mes principaux jeux sont black ops 4 battlefield V , rocket league , les jeux auquel je joue moins sont fortnite overwatch , je suis sur ps4 Par contre je n'utilise plus la qos du netduma mais celle de mon bt home hub 5 sous lede 17.01.6 ....
Administrators Netduma Fraser Posted January 15, 2019 Administrators Posted January 15, 2019 Have you got devices connected to the BT hub opposed to the R1 then?
Dopam-IT_1987 Posted January 16, 2019 Author Posted January 16, 2019 non je n'en ai aucun juste l'ethernet du netduma
Administrators Netduma Fraser Posted January 16, 2019 Administrators Posted January 16, 2019 Okay just checking based on your settings, would put the R1 in its DMZ though
Chive972 Posted January 23, 2019 Posted January 23, 2019 Pourquoi le serveur dhcp de ta box orange est désactivé ?
