Philips HUb
Hi guys just got myseld a ophilips hue hub and when i plug it in to eth 4 the light is red not white, i have tried everything any help or advise please, i have changed cable and reset router all the usual stuff and the app says its conn3ect strangley
TIA dave
What connection issues are you having? When it's red it usually just means there is no data being passed at that time. Which I assume it wouldn't given you'd just change the settings every so often. What do you mean it says it connects strangely? Whats the exact message it gives you?
