Mathew mcdoanld Posted October 11, 2018 Posted October 11, 2018 I pay for 150 meg download and am not getting it I need help
Featured Comment pollutionblues Posted October 11, 2018 Featured Comment Posted October 11, 2018 19 minutes ago, Mathew mcdoanld said: I pay for 150 meg download and am not getting it I need help Hi, Welcome to the forum. Can you give us a few more details to help us diagnose your issue please. What device are you using? R1 or XR500? what is your physical setup? wall > modem > Netduma > all devices or wall > modem/router combo > Netduma > all devices, or something different? Are you using a wired PC to test? There are also helpful guides here: Netduma R1 optimal settings: http://support.netduma.com/support/solutions/articles/16000023979-optimal-settings-guide#Speed DumaOS optimal settings: http://support.netduma.com/support/solutions/articles/16000076586-dumaos-optimal-settings-guide-speeds Please do not post in the 1 on 1 section unless instructed to do so by Netduma staff. I have moved this post to the correct section.
XmasTeaTowel Posted October 13, 2018 Posted October 13, 2018 I have found, even with 'share excess' on.. Unless ALL devices have even distribution, none ever hit full speed. (I only alter this if say - twich streaming and don't want ANY interruptions. Under normal use and gaming the high priority and anti buffer bloat is enough) It's like it auto throttles everything that's not the top number even if no other devices are in use. Try resetting distribution up/down if you haven't already. Then test again. Also test something on LAN and compare it to wireless. It may just be your devices wirless capability holding you back.
