Built in speed test odd results.
Guest Killhippie
Guest Killhippie
If you set the router up it goes though the motions of doing its speed test. So yesterday when I factory reset my router it shows my lowly speeds as 56.66Mbps down and 16.63 up. Now all is fine until you go into QoS and click on the fly-out menu where you can adjust your own speeds it's now showing 16.624384. Oddly if I redo the speed test if the upload is 16.59 the flyout menu shows exactly that, but anything with a 6 in it like 16.63 and I end up with 16.243873 or there about. I've uploaded the firmware again, factory rest twice and it always bugs out if the decimal place in the speed test shows 16.61 and upwards, if it is below as I mentioned like 16.59 all is well. Now you can change this of course yourself, but why is it doing this? I don't seem to remember this issue on 2.3.2.22.
Great find! Thank you for letting us know. We will try to reproduce this to then debug.
