Xbox One wired connection keeps switching to dormant and wired on local devices...
Hi, Im on the Netduma R1 and when im gaming on the Xbox One X using a wired connection, the local devices on the netduma  keeps switching from 'wired to Dormant' on the Xbox whilst gaming, any help would be appreciated.
Hi, welcome to the forum! Is it possible you could screenshot this or let us know exactly what the Xbox error states?
Is this causing any issues with gaming? Is this when you run a connection test on the Xbox, and have you tried switching the cable to the Xbox?
Hi, Jack i have noticed it flicking from wired to dormant whilst im gaming on the Xbox, i have attached couple of screen shots, thanks Chilly
Ah right. Ultimately this shouldn't matter - does the Xbox stay online when this happens? It'll just be how the Device Manager is detecting it.
If your Xbox is going offline every now and again, try switching the Ethernet cable connecting it to the Netduma. Dormant status shouldn't matter though. I hope this helps!
