Geo-Filter error: uncaught exception: Unmatched device - help
Hi,
When I login to my XR500 and got to Geo-Filter
I get an error uncaught exception: Unmatched device
And no option to add new ones and current ones don't load
I have rebooted the router and it still the same.
I am running the latest Firmware: V2.3.2.22
If I need to reset to factory, can I use a restore setting file, that I have just created?
Any ideas?
Its because the device that was previously added has had its name changed or been disconnected when upgraded. Rename the device that was added back to what it was before. Otherwise factory reset, if you use the config just made it will add the device back to Geo-Filter and you may get the same issue again but can try
