geo filter HELP
hello i just upgrade from netduma to xr500 but im having problems with the geo filter as you can see on the picture i keep my radius on 2245km to connect german server but it keep joining lobby out of the zone but the problem the lobby i connect shows up in north america but its actually a european server beucase i play around with 70-90 ping on it anyway i can fix this
I can't see your picture. Sounds like you have it set to Spectating Mode rather than Filtering Mode or you have strict mode off.
Can't see the picture?
What game are you playing?
Sounds like strict mode is off or incorrectly located server
It's working as expected. Blocking the server outside your radius and allowing the one inside your radius.
