Wifi lost signal and geo filter all red
KCINCO
Hello my i have my Phone connected wifi and it losses the connection. Its connected to the r1 but no connected to the network.
And my geo filter its all with Red points. No yelow no blue... Its all red
Hi,
First can you go to Settings >> Miscellaneous and make sure that 'Wifi workaround' is disabled.
Everything on the GeoFilter is meant to be red :) Other colours are for different slots on the GeoFilter or Admin mode which isn't publicly available.
It was enable. Just disable.. Was this the problem?
Possibly. Disabling Wifi workaround has fixed problems in the past so let us know if disabling it fixes your problem :)
