Help with putting R1 in DMZ
EffinFancy
Guest Netduma_Iain
What is your upstream router? Can you access its interface? If not please go to "Device Manager" and you'll see a blue box at the top. Click the button and it will take you to your other router. You need to search around there for either "Modem mode", "Bridge mode" or "DMZ".
Self-explanatory.  I can't find the place to put the router in DMZ.  I may be super dense and it may not be possible...Thanks!
try looking in you wan settings
router model and ill look it up or google ur self
Guest Netduma Fraser
Figured it out.  Thanks for the help.  Is there a way to delete my thread?
Yes I can delete your thread. However, future owners of the R1 may find this thread helpful so I'll leave it up.
