lefteris.lydios Posted October 20, 2017 Posted October 20, 2017 Can someone please tell me if it's possible to view NETDUMA's GUI from my PC, even though it's in a different subnet?
Administrators Netduma Fraser Posted October 20, 2017 Administrators Posted October 20, 2017 Tick remote access from WAN in misc settings, set a username & password for the interface then access by typing your public IP in
lefteris.lydios Posted October 20, 2017 Author Posted October 20, 2017 Thanks for your reply Fraser. I must be doing something incorrectly. First of all 2 DHCP Servers can't exist in the same network. Correct? Second, there must be a different Subnet Mask in the first router, other than 255.255.255.0 Is this right? SOLVED thanks
Administrators Netduma Fraser Posted October 21, 2017 Administrators Posted October 21, 2017 What was the solution you had?
lefteris.lydios Posted October 21, 2017 Author Posted October 21, 2017 I was typing 192.168.88.1 instead of the wan ip. Everything is fine now.
Administrators Netduma Fraser Posted October 22, 2017 Administrators Posted October 22, 2017 Great I'll close this thread.
