Problem geofilter no load
hello everyone ... tonight the geo filter decided not to load anymore and stay in the upload page I reset the router with factory reset but the problem has not resolved ... the ps4 is connected to the router and the connection works, i do not understand
I found that the problem occurs when I manually set the cloud server ... if I leave it automatically the geo filter works
edit
with 41-37-28 geofilter  is on
with 41-38-28  geofilter no load
netduma does not find my ps4 anymore, with a frizbox router connects without problems, all this without having changed any settings in the netduma
I tried all the ports lan of the r1 with new and different cables and did not find the ps4, after losing one hour of time I changed it with another router and not problems
Have you checked the PS4 IP in it's network settings with the IPs in device manager? It may appear as a nameless/unnamed device
