lele19-89 Posted October 17, 2017 Posted October 17, 2017 Hi everyone ... an information if I manually set the ports for my playstation in this way : port 1-65535 tcpudpdoes it mean that ps4 is in dmz?do you think that setting can be fine?sorry the bad english use a translator
Administrators Netduma Fraser Posted October 18, 2017 Administrators Posted October 18, 2017 Would you be port forwarding on the R1? You don't need to port forward like that for the PS4. It is overkill and may also affect your other devices. Either use UPnP or just port forward the required ports for the PS4
lele19-89 Posted October 18, 2017 Author Posted October 18, 2017 I opened the door only on the ps4 device and its ip
Administrators Netduma Fraser Posted October 19, 2017 Administrators Posted October 19, 2017 I don't understand can you clarify please
lele19-89 Posted October 19, 2017 Author Posted October 19, 2017 ports 1-65355 are set only on ip ps4. the netuma modem is dmz connected to another router, my question is ? Do 1-65355 ports open on the ps4 can in this way damage its network and game navigation causing problems?
Administrators Netduma Fraser Posted October 19, 2017 Administrators Posted October 19, 2017 It is unwise to port forward everything to the PS4 like that yes. R1 in DMZ, then port forward only necessary ports or use UPnP.
