Vpn Adavanced Conection not working please help so mad!
hey please help me im so banging my head on the wall right now i have just recieved my netduma and the first thing i want to do is connect to my VPN that i have been ujsing for over a year now , however after a bit of browsing around i have come to the understanding that if i have a hide my ass vpn i can just bang my details in and of i go but i do not have a hide my ass vpn i use one called PureVpn so my question is how do i connect to this it looks like i have to use the advanced settings and i have tried this http://forum.netduma.com/forum/7-features/ but still doesn't connect whats going on please let me know as this is one of the main features for me .
many thanks
yup so the files in UDP & TCP are the config files for different servers. Pick a server you want and open the file, copy the entire file and put it in the advanced section.
Then open the ca.crt file in notepad. Copy the entire file then paste it into the bottom of the advanced section. Make sure to put a at the line above the file & a at the bottom.
Does that make sense?
Then open the ca.crt file in notepad. Copy the entire file then paste it into the bottom of the advanced section. Make sure to put a <ca> at the line above the file & a </ca> at the bottom.
i understand but i don't understand the  put a <ca> at the line above the file & a </ca> at the bottom this is what i have so far i post :-
client
dev tun
proto udp
remote vlbr-ukl1-ovpn-udp.purevpn.net 53
persist-key
persist-tun
ca ca.crt
tls-auth Wdc.key 1
cipher AES-256-CBC
comp-lzo
verb 1
mute 20
route-method exe
route-delay 2
route 0.0.0.0 0.0.0.0
auth-user-pass
auth-retry interact
explicit-exit-notify 2
ifconfig-nowarn
auth-nocache
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
please paste the <ca> at the line above the file & a </ca> at the bottom. where they need to go?
client
dev tun
proto udp
persist-key
persist-tun
ca ca.crt
tls-auth Wdc.key 1
cipher AES-256-CBC
comp-lzo
verb 1
mute 20
route-method exe
route-delay 2
auth-user-pass
auth-retry interact
ifconfig-nowarn
auth-nocache
client
dev tun
proto udp
persist-key
persist-tun
ca ca.crt
tls-auth Wdc.key 1
cipher AES-256-CBC
comp-lzo
verb 1
mute 20
route-method exe
route-delay 2
auth-user-pass
auth-retry interact
ifconfig-nowarn
auth-nocache
ok try this
client
dev tun
proto udp
persist-key
persist-tun
ca ca.crt
tls-auth Wdc.key 1
cipher AES-256-CBC
comp-lzo
verb 1
mute 20
route-method exe
route-delay 2
auth-user-pass
auth-retry interact
ifconfig-nowarn
auth-nocache
client
dev tun
proto tcp
remote vlsa-ukl1-ovpn-tcp.purevpn.net 80
persist-key
persist-tun
ca ca.crt
tls-auth Wdc.key 1
cipher AES-256-CBC
comp-lzo
verb 1
mute 20
route-method exe
route-delay 2
float
auth-user-pass
auth-retry interact
ifconfig-nowarn
-----BEGIN OpenVPN Static key V1-----
e30af995f56d07426d9ba1f824730521
d4283db4b4d0cdda9c6e8759a3799dcb
7939b6a5989160c9660de0f6125cbb1f
585b41c074b2fe88ecfcf17eab9a33be
1352379cdf74952b588fb161a93e13df
9135b2b29038231e02d657a6225705e6
868ccb0c384ed11614690a1894bfbeb2
74cebf1fe9c2329bdd5c8a40fe882062
4d2ea7540cd79ab76892db51fc371a3a
c5fc9573afecb3fffe3281e61d72e915
79d9b03d8cbf7909b3aebf4d90850321
ee6b7d0a7846d15c27d8290e031e951e
19438a4654663cad975e138f5bc5af89
c737ad822f27e19057731f41e1e254cc
9c95b7175c622422cde9f1f2cfd3510a
dd94498b4d7133d3729dd214a16b27fb
-----END OpenVPN Static key V1-----
Note to self, when you get errors like
" connect to [AF_INET]*.*.*.* failed, will try again in 5 seconds: No route to host "
its because there server is down
client
dev tun
proto tcp
persist-key
persist-tun
ca ca.crt
tls-auth Wdc.key 1
cipher AES-256-CBC
comp-lzo
verb 1
mute 20
#route-method exe
#route-delay 2
#route 0.0.0.0 0.0.0.0
float
#auth-user-pass
#auth-retry interact
ifconfig-nowarn
