Administrators Netduma Iain Posted May 29, 2015 Administrators Share Posted May 29, 2015 Raddy you free for a moment, can you chat in the chat room please. Unrelated to this Sam Link to comment Share on other sites More sharing options...
RADDY1993 Posted May 29, 2015 Share Posted May 29, 2015 Once done 1) turn of your Duma at power and connect to the reset Hub as in Duma instructions and turn it on wait a minute for both routers to fully turn on. 2) Go into the Hub and assign your Duma a IP as we said before. 3) Connect PC to Duma via Ethernet and try to access the GUI is you can double check your Ip in Device Manager and in the Hub if they match then enter that in the DMZ of the Hub and reboot Hub and Duma then try to connect to internet. Link to comment Share on other sites More sharing options...
SamC Posted May 29, 2015 Author Share Posted May 29, 2015 Okay netduma is in DMZ, Both the ip of the netduma and the ip in device manager as the same and i finally have internet connection through the net Duma Thankyouu Link to comment Share on other sites More sharing options...
Administrators Netduma Iain Posted May 29, 2015 Administrators Share Posted May 29, 2015 Thanks Raddy Link to comment Share on other sites More sharing options...
SamC Posted May 29, 2015 Author Share Posted May 29, 2015 Thankyou Both Link to comment Share on other sites More sharing options...
SamC Posted May 29, 2015 Author Share Posted May 29, 2015 NAT Type is Strict :/ Link to comment Share on other sites More sharing options...
RADDY1993 Posted May 29, 2015 Share Posted May 29, 2015 NAT Type is Strict :/ What console you using ? Link to comment Share on other sites More sharing options...
SamC Posted May 29, 2015 Author Share Posted May 29, 2015 X1 Link to comment Share on other sites More sharing options...
RADDY1993 Posted May 29, 2015 Share Posted May 29, 2015 X1 So the IP in the Device Manager of your Duma is the IP you have enterd in the DMZ in your Home Hub ? Link to comment Share on other sites More sharing options...
SamC Posted May 29, 2015 Author Share Posted May 29, 2015 yes i have Link to comment Share on other sites More sharing options...
RADDY1993 Posted May 29, 2015 Share Posted May 29, 2015 Are you on ADSL or VDSL Link to comment Share on other sites More sharing options...
SamC Posted May 29, 2015 Author Share Posted May 29, 2015 ADSL, i take it that VDSL Is fibre optic? IF this helps i was on strict once before but i disabled PnP and i had to put my xbox one in DMZ To fix it Link to comment Share on other sites More sharing options...
RADDY1993 Posted May 29, 2015 Share Posted May 29, 2015 ADSL, i take it that VDSL Is fibre optic? IF this helps i was on strict once before but i disabled PnP and i had to put my xbox one in DMZ To fix it I have a PS4 so dont know nuch about XB1 but can you disable UPNP in the XB1 settings ? Link to comment Share on other sites More sharing options...
Administrators Netduma Iain Posted May 29, 2015 Administrators Share Posted May 29, 2015 have you got the Geo-Filter disabled? Link to comment Share on other sites More sharing options...
SamC Posted May 29, 2015 Author Share Posted May 29, 2015 No i meant to fix it when i was using my ISP router i diabled UPNP in my ISPs routers settings and i put it into DMZ Link to comment Share on other sites More sharing options...
SamC Posted May 29, 2015 Author Share Posted May 29, 2015 No i have not Link to comment Share on other sites More sharing options...
Administrators Netduma Iain Posted May 29, 2015 Administrators Share Posted May 29, 2015 Can you disable it, restart the game & check if your NAT is open please. Link to comment Share on other sites More sharing options...
RADDY1993 Posted May 29, 2015 Share Posted May 29, 2015 No i meant to fix it when i was using my ISP router i diabled UPNP in my ISPs routers settings and i put it into DMZ You dont need to disable UPNP in Hub as its used for other devices aswell, i ment turn of UPNP in the XB1 settings. Turn UPNP back on in Hub. Link to comment Share on other sites More sharing options...
SamC Posted May 29, 2015 Author Share Posted May 29, 2015 You cant turn it off in the XB1 settings, and it still on Link to comment Share on other sites More sharing options...
SamC Posted May 29, 2015 Author Share Posted May 29, 2015 Anyway i can out my xbox 1 into dmz in The netduma? Link to comment Share on other sites More sharing options...
RADDY1993 Posted May 29, 2015 Share Posted May 29, 2015 You cant turn it off in the XB1 settings, and it still on Take a look at THIS it may help. Link to comment Share on other sites More sharing options...
Administrators Netduma Iain Posted May 29, 2015 Administrators Share Posted May 29, 2015 Sam please make sure your Geo-Filter is disabled before trying anything else first. Link to comment Share on other sites More sharing options...
RADDY1993 Posted May 29, 2015 Share Posted May 29, 2015 Anyway i can out my xbox 1 into dmz in The netduma? You can Reserve an IP in the Duma like this : Link to comment Share on other sites More sharing options...
SamC Posted May 29, 2015 Author Share Posted May 29, 2015 Ian i have checked and its still not working thanks anyways Link to comment Share on other sites More sharing options...
Administrators Netduma Iain Posted May 29, 2015 Administrators Share Posted May 29, 2015 Have you got UPnP enabled right? Link to comment Share on other sites More sharing options...
