SamC Posted May 28, 2015 Posted May 28, 2015 Hi can anyone help i am able to connect wirelessly over my phone to the router but no on my pc?
Netduma Staff Netduma Crossy Posted May 28, 2015 Netduma Staff Posted May 28, 2015 Hi Sam, welcome to the forums! What is the exact error message that you are getting? Could you make sure you have not set up a static IP on the PC you are tying to connect with.
SamC Posted May 28, 2015 Author Posted May 28, 2015 I have a static IP on my PC , i will remove it now
Netduma Staff Netduma Crossy Posted May 28, 2015 Netduma Staff Posted May 28, 2015 I have a static IP on my PC , i will remove it now Ok, usually that is the issue as it causes conflicts with the Netduma - Let is know if it works
SamC Posted May 28, 2015 Author Posted May 28, 2015 Thankyou so much it worked and every things working, A***++++ on Customer service thankyouu
Netduma Staff Netduma Crossy Posted May 28, 2015 Netduma Staff Posted May 28, 2015 Thankyou so much it worked and every things working, A***++++ on Customer service thankyouu Awesome! Great news that it is fixed Any more questions feel free to make a new thread with your question.
Administrators Netduma Iain Posted May 28, 2015 Administrators Posted May 28, 2015 Hi Sam, welcome. Thanks Crossy!
