bagsta69 Posted March 9, 2017 Posted March 9, 2017 Cheers for the info mate, Do you know if you need to enable boost mode if you have a PS4 Pro?
PharmDawgg Posted March 9, 2017 Posted March 9, 2017 MrTrakky I love the intro music. Thanks for the vid.
MrTrakky Posted March 9, 2017 Author Posted March 9, 2017 Cheers for the info mate, Do you know if you need to enable boost mode if you have a PS4 Pro? yes mate I show you how in the video
MrTrakky Posted March 9, 2017 Author Posted March 9, 2017 MrTrakky I love the intro music. Thanks for the vid. cheers mate
adel75 Posted March 10, 2017 Posted March 10, 2017 Cheers for the info mate, Do you know if you need to enable boost mode if you have a PS4 Pro? boost mode is ONLY for the PS4 pro , for games not Pro optimised . basically boost mode higher the GPU clock.
MrTrakky Posted March 11, 2017 Author Posted March 11, 2017 boost mode is ONLY for the PS4 pro , for games not Pro optimised . basically boost mode higher the GPU clock. I know mate hence why I said Ps4 Pro
