speed test
Please try the following:
  • Have speeds set in bandwidth settings
  • Reactive Algorithm
  • 100% anti-flood
  • Share excess enabled
  • Disable deep packet in misc
  • Enable turbo mode
  • Enable super turbo mode
Turbo & super are both enabled at the same time? Are you using the same ethernet cable to test directly to your modem?
