Port #4 does not work
  1. What firmware version are you on?
    1.03.6h
  2. What speeds do you get from multiple speed tests?
    954 down/954 up
  3. What is your current setup?
    ISP -> R1 -> Wired PC
  4. What is your specific issue?
    When I plug my wired PC into Port #4 it does not get a connection. If I use that same cable and plug it into any other port it works fine.
  5. Any other information (such as settings you may have previously tried).
    When I plug the cable into port #4 the LED light indicator does not light up as well. I have tried different cables as well and all have the same results where the port does not work.
