Starting all over Need help remotely
I dont know how but my setting in router did not save. Now when i play destiny , i feel really laggy. Dr Donkey Kong (xbox1 gamertag) Helped me before remotely and it appeared to go good. Now everything is lost and i dont remember how to get them back. Please help.  I went through tutorials and all but there were other things that were done that were not on it.
Speeds:
  • Preemptive (below 60mbps) or Reactive Algorithm (above 60mbps)
  • 100% anti-flood
  • Share excess enabled
  • Disable deep packet in misc
  • Enable turbo mode (if above 120mbps or can't get higher without it)
  • Enable super turbo mode (above 300mbps, turbo has to be enabled also)
ALL devices should be connected to the R1. For gaming:
70/70 anti-flood
Console in hyper traffic
Use Destiny Profile or
- 1000km radius
- Strict off
- Ping assist 0ms
R1 WAN IP in ISP hub DMZ. Disable UPnP & Port forwarding on ISP hub.
Use UPnP OR port forwarding on R1 not both
Disable UPnP forwarding in miscellaneous settings
Enable cookies in miscellaneous settings
Only reboot from miscellaneous settings don't unplug it.
