Firmware upgrade help.
1.) Current version 1.03.3
2.) Not sure of speeds
3.) Setup - Cisco DPC3008 cable modem, NetDUa R1, Xbox One. ( I plug in a laptop for troubleshooting)
4.) I would like to upgrade the firmware, but after reading your post. It needs your touch.
5.) If you can provide a check list of thing to change pre-upgrade, I feel I could complete it on my own.
Thank you
Crazy240sx
Thank you
Crazy240sx
Post here and Fraser will get back to you when it's safe to upgrade. http://forum.netduma.com/topic/11018-major-netduma-upgrade-now-available-v-1036/
We could not access your router. Please ensure the R1 WAN IP is in the DMZ of your ISP hub if applicable. UPnP & Port forwarding is disabled on your ISP hub if applicable and that remote access is ticked on the R1 in settings > miscellaneous.
The cable modem should be in Bridge mode. I have enabled WAN access on the R1. This post was done from that internet connection. (ip 98.xx.xx.116)
