JohnnyLawrence Posted October 22, 2016 Posted October 22, 2016 I bought a netduma router 2 months and need help with strict mode for destiny can any body relate/help?
Slipknot31286sic6 Posted October 22, 2016 Posted October 22, 2016 Unchecked strict not supposed to be checked as it's p2p no dedicated servers on destiny
JohnnyLawrence Posted October 22, 2016 Author Posted October 22, 2016 Can you walk me through your settings so I know I have everything set up for optimal performance
Slipknot31286sic6 Posted October 22, 2016 Posted October 22, 2016 Go to profile destiny, I play cod. Should work. Unchecked strict mode. I don't play destiny. What settings u wanna know
Administrators Netduma Fraser Posted October 23, 2016 Administrators Posted October 23, 2016 Hey, welcome to the forum! As above use the Destiny profile, that will un tick strict which is needed for Destiny otherwise you have the booting issue. Other than that 70/70 anti-flood, console in hyper traffic you should be good.
