Huthayfa Posted September 20, 2016 Posted September 20, 2016 Hello, I have started facing some issues two days ago, bugs call out many times and some crashes, no response to my command from the netduma. I was wondering if a firmware reinstall would help with such case ... thanks.
RoyDavis77 Posted September 20, 2016 Posted September 20, 2016 Have you tried a factory reset? i used to get a slow or unresposive netuma gui, but a factory reset fixed the problem.
Huthayfa Posted September 20, 2016 Author Posted September 20, 2016 Have you tried a factory reset? i used to get a slow or unresposive netuma gui, but a factory reset fixed the problem. thank you so much ... I will make a try . thanks
Huthayfa Posted September 20, 2016 Author Posted September 20, 2016 problem fixed ... yeeah ... that is excellent. lets hope nothing wrong goes again
