need help
Madjust
hi for some reason im getting reallt slow speeds through the netduma with virgin media ive got 152mb download and 12 upload but only getting between 2 and 7 download but upload stays the same any help pls
Hey Madjust :)
Can you read through this to see if it helps.
Also, make sure you're on the latest Firmware version 1.03.4  If not, it can be found here.  Please follow the instructions carefully   :)
If you're still having issue after the update, I suggest you follow the instructions in the link below and one of the team will be able to assist you further.   :)
Thanks Dirty Dog,
Glad its working MadJust & welcome :D
