issue finding lobby with 2 people on same console
Mr.Stallion0013
So when me and my GF play blops2 together on the same console it seems to take a very long time to get into a lobby. And when we finally do get put in a game as soon as its over we get lobby booted. Playing solo we can get right into a game its only when we play together. Just wondering if anyone on here might know why.
I haven't heard of this issue before, when you get booted from a lobby do you see a padlock appear on your map?
ok when you get booted the padlock is showing you where the game wants to put you. Can you fit the filter inside the padlock?
I can but then it defeats the purpose of getting the Duma. I'm in the middle of the U.S. and get good lobbies with the rest of the middle of the U.S. its when I get connected to either the east coast or the west coast I get very bad lag. My main question is why does it only happen when we play together not solo.
Sorry I should clarify, you'll probably find the padlock has a very low ping and has an incorrect location. See this please: http://forum.netduma.com/topic/1723-cloud-incorrect-locations/
As to why it happens, I have no idea? I've never heard of that issue which is quite surprising as I doubt you're the first person to do split screen with it.
That's the main reason I posted this. To see if it was just me or others where noticing this also. It might be my ISP also cause before I had the Duma when we played together the connection would be twice as bad as usual. I'm not sure if this is a byproduct of that or not.
Oh I see, what is your upload & download speed?
Ok the ISP shouldn't be an issue. Maybe the game tries to find you with other split screen players? I don't know but if you can get us the IDs they maybe near your home and that would fix the issue.
