Zennon Posted July 31, 2016 Posted July 31, 2016 You connect the duma to your existing home hub as the duma has no modem. HH > Ethernet > Port 1 Netduma then put the duma's WAN IP into the HH DMZ http://support.netduma.com/en/support/solutions/articles/16000022359-how-do-i-open-my-nat-
gustins32 Posted July 31, 2016 Author Posted July 31, 2016 So it's meen I can't use netuduma as modem, even if i change PPPoe setting ☹️☹️☹️☹️
Zennon Posted July 31, 2016 Posted July 31, 2016 So it's meen I can't use netuduma as modem, even if i change PPPoe setting ☹️☹️☹️☹️ No the Netduma does not have a modem but using your HH connected as above and the duma in its DMZ you are good to go and you will be using all the features of the duma and not the HH as you connect all devices to the duma. Remember to turn off the HH's WiFi. You can use Hauwei HG612 modems with the duma using PPPoE of the duma.
gustins32 Posted July 31, 2016 Author Posted July 31, 2016 Cheers Zennon, i did already like that, and I really enjoying netduma, it's absolutely
Zennon Posted July 31, 2016 Posted July 31, 2016 No probs I will lock the thread, If you have any other question's please feel free to make a new one.
