Hi. i havent used my netduma in about a year. i hooked up everything and followed the quick start guide but the ssid/ network name is not showing up. the green wifi buttons are not on but the power is. i think it needs fully reset or something but idk how to do that. i looked through some forum topics and someone had a similar problem i think the wifi on the r1 was turned off. also i cant access the r1's interface i tried 192.168.88.1 and r1/. please help
the r1 is got the 1.3 update. i factory reset it and the ssid only shows up when connected to ethernet when it is connected it says No internet access and the 2nd green light is on
but it only connects shows the network name on my computer when connected through ethernet when i disconnect the ethernet it dissapears
So the SSID in your list of wifi routers disappears ?
I would reconnect via Ethernet and check you have wifi set up correctly I use WPA2-PSK you can give it your own SSID and password.
