The13ghost Posted June 18, 2016 Posted June 18, 2016 ok all devices connect to wifi have lost connection , shows loading but wont connect , all wire devices are working i done the following rebooted router factory reset enable and disable wifi work-around change wifi channel change security mode unplug both router and modem (10 minutes) this is the first time i had this problem
Zennon Posted June 18, 2016 Posted June 18, 2016 Now this is how you write up a support thread, nice job at listing the cause and your effect. The only thing you have not tried it to see if your ISP routers WiFi has been enabled, could you check please, thank you.
The13ghost Posted June 18, 2016 Author Posted June 18, 2016 Now this is how you write up a support thread, nice job at listing the cause and your effect. The only thing you have not tried it to see if your ISP routers WiFi has been enabled, could you check please, thank you. wifi was enable , i disable it and enable it back no change , when i try connection connecting my laptop to wifi it says bad wifi signal , im less then 5ft from the router
Zennon Posted June 18, 2016 Posted June 18, 2016 WiFi needs to be off on your ISP router and Netduma's WiFi turned on. I use wpa/psk2 security mode and set a new password. And i use a WiFi analyzer to find the lest congested channel http://www.howtogeek.com/197268/how-to-find-the-best-wi-fi-channel-for-your-router-on-any-operating-system/
The13ghost Posted June 18, 2016 Author Posted June 18, 2016 WiFi needs to be off on your ISP router and Netduma's WiFi turned on. I use wpa/psk2 security mode and set a new password. And i use a WiFi analyzer to find the lest congested channel http://www.howtogeek.com/197268/how-to-find-the-best-wi-fi-channel-for-your-router-on-any-operating-system/ thank you, problem solve . my problem was my isp router , the wifi would not stay off , i would turn it off and save it , but it would turn back on , i call my internet service provider and they fix it , now my wifi is actually working better then before . thanks again
Zennon Posted June 18, 2016 Posted June 18, 2016 Great news If you have any other questions feel free to make another post. I will lock the thread now.
