Seven Posted April 9, 2016 Posted April 9, 2016 I've had this issue on the old and new firmware, i am currently running fw (1.03.6g) i set my duma up and have all the settings how i like them. for it just to reset in a few days and i have to do it all again, it's really tedious and it's getting annoying :'( any help would be much appreciated Thanks in advance apologies for the poor spelling
Seven Posted April 9, 2016 Author Posted April 9, 2016 I did but when it auto resets it gets un-ticked again
Zennon Posted April 9, 2016 Posted April 9, 2016 Can you make sure the power supply jack is pushed into the Netduma's power port fully.
Zennon Posted April 9, 2016 Posted April 9, 2016 Ok something to try would be a cold boot. So turn off the Netduma for 5 minutes then reboot, keep and eye on things after that. Also make sure it is not to near any other devices give them a good distance.
Seven Posted April 9, 2016 Author Posted April 9, 2016 okay, i'll give that a shot. hopefully it will be okay, I love my duma thanks for the help man
