Ping problems
I keep getting the something went wrong prompt when the R1 test ping. I have disabled cookies and no adblocker. Can't find anything else that might be causing this. All help is greatly appreciated.
Guest Netduma_Iain
Hi Super,
If you disabled adblockers and viruses the other common cause is you've enabled some devices on your VPN section of the router. Please make sure to switch off all devices in the VPN section :)
Ive noticed a few people calling you Lain , next i will be calling you Lan ;)
