Blaikie Posted March 13, 2015 Posted March 13, 2015 I'm used to switching between 70% and 100% in congestion control but all of a sudden today it's not saving the settings and I'm stuck on 70% Any ideas?
Netduma Staff Netduma Crossy Posted March 13, 2015 Netduma Staff Posted March 13, 2015 I'm used to switching between 70% and 100% in congestion control but all of a sudden today it's not saving the settings and I'm stuck on 70% Any ideas? Try restarting the router. When you drag it and release it at 100%, what happens? Does it just change back once you refresh the page.
Blaikie Posted March 14, 2015 Author Posted March 14, 2015 Try restarting the router. When you drag it and release it at 100%, what happens? Does it just change back once you refresh the page. Yes, it just changes back to the previous settings.
Netduma Staff Netduma Crossy Posted March 14, 2015 Netduma Staff Posted March 14, 2015 Have you tried restarting the router?
Blaikie Posted March 14, 2015 Author Posted March 14, 2015 Have you tried restarting the router? I think it's applying the settings today but now the netduma is not recognising the BT Home hub router via the PoE / WAN (Red wire) connection. The port light is not lit and I've tried resetting both routers. Was there a firmware update yesterday or something? To clarify, the netduma is sitting doing nothing right now because I can't connect to it. This is how I'm setup (I've tried switching the Ethernet ports). Also the internet works fine connected via the BT Home Hub itself.
Guest Netduma_Iain Posted March 14, 2015 Posted March 14, 2015 The update is not automatic Blakie, so nothing has changed externally. Have you changed any settings that made it do that? Physically that looks correct. Can you access 192.168.88.1 from your (yellow)wired PC?
