Mikehorne24 Posted March 12, 2016 Posted March 12, 2016 the 12 digits during the start of my router is not working as my password
Administrators Netduma Fraser Posted March 14, 2016 Administrators Posted March 14, 2016 Hey welcome to the forum! It is case sensitive so make sure you're inputting it correctly. If that doesn't work try the above password incase you've factory reset. Otherwise connect via ethernet cable and change the wifi password manually.
