Problem whit Live streaming , help please
I can not more send live stream out of take theater up in Black ops 3 , they Said my Connexion is not enough on the moment . I have 100 download and 6 upload , i had never problems before , i have try al on the Netduma router , i have try back on my modem alone and Nothing works , the movie falls out after Some minute
If it is not working on your modem either then it seems there is an issue elsewhere, with your modem/line. Have you tested your speeds recently to see if you're experiencing a drastic drop?
all is the same , Nothing else have changed from speed , maybe i gonna cal Tomorrow near my provider , just i have take a game up for 7 minuten and this game falls not off , then after i take game up from more then 10 minute and my hole game fall out , i get this not
I have try this so many times , i have everytime other speeds , i have try three times just , first time download 64.24 and upload 2.44 then second time download 74.45 and upload 2.26 then last time download 93.25 and upload 5.86 , my internet for what i pay is 100 download and 6 upload , what must i set in the bandwidth , they changed everytime my Speedtest
Speed test can be inconsistent but that is quite a big change. This occurs on your modem also? If so this sounds like an ISP issue
what u prefere then that i do , i have set 72 download and 5 upload in bandwidth , i play Wel very Nice games last days , maybe iTS best that i let this ,
With the upload changing quite a bit that may be why you can't keep it consistent. I'd prioritise the stream device so it gets whatever your upload is at the time.
Sorry , but i dont understanding what u mean whit stream device
I mean your PC or console whichever you're using to stream
