Knomax Posted February 13, 2016 Posted February 13, 2016 Hello... I connect my pc to netduma first wireless...it recognize MAC address of wireless card and i give it a specific Ip from DHCP Lease. Then i coonect the same pc to netduma with cable..it recognize MAC address of ethernet card and i give it a specific Ip from DHCP Lease...everything ok. When i connect my ps3 to netduma with cable..it recognize MAC address for wired connection and i give ip from DHCP Lease...everything ok. But when i try to connect it wireless it doesn't recognize MAC address for wireless and i can't give Ip from DHCP Lease because it doesn't recognize it as different device...it gives two Ip's in the console.In device manager it says that device is active...but "dormant"!!!!Via wireless connection. I reset netduma to factory settings two times...nothing change..i think is a "bug".
Asentrix Posted February 13, 2016 Posted February 13, 2016 Second time it's been reported today , guessing it's a bugAdmins should see this and look into it
Knomax Posted February 13, 2016 Author Posted February 13, 2016 I do everything i can do before posting...it isn't my "fault" configuration...i hard reset my console...my netduma...and so on to be sure. With previous firmware it recognize it as different device and this is correct that it must do. Sorry for my English.
