Speedport w724v and Netduma problems
Hey guys i used a Speedport w724v Telekom Germany Routerr and will use the Netduma. My Problem is the w724v doesnt support DMZ BridgeMod Modemonly or ppoe. I cant pass the Connection straight out of my w724v to the Netduma without any Portkills or something
anybody the same Problem with the same Router or snother which doesnt support the Mods ?
I would be pleasefull for help
sorry for my English
greats from Germany
Okay. On the duma in settings > miscellaneous enable port forwarding. Have UPnP enabled and no port forwarding rules. Disable the Geo-filter and hard reboot the console. Check to see if you have an open NAT from the consoles network settings
