[SWITCH] Mini switch gigabite usb auto powered
glaglaman
Hello,
I just bought a mini gigabite switch wich is auto powered in USB.
I would like to know if it's compatible with the netduma ?
(it's just a question before pluging it, I don't want to fried the whole thing)
I would like to just de-concentrate the port 5 to plug my NAS, TV, Laptop etc .... all non gaming device (those are on port 2 to 4)
Thanks.
If you're talking about a USB hub, you should be OK if it's USB certified. However, as with all devices there is a chance that something could go wrong.
You can use switches with the duma. If you're asking whether you can power it by using the USB port on the duma I think you would be able to yes
