Geofilter Advanced Settings Question
pr0minence
Would it make a difference to select udp/tpc on advanced settings (Playstation Network - Playstation Pa - Advanced)? Also is there a way to add more than just port 80 with a seperation on that same list of settings such as 80:446:990 etc. ?
This would disable the service you are using. The playstation uses a certain set of ports so by selecting port 80 from the advanced menu this would disable the Playstation option, so if you are using the GeoFilter for playstation, it will not work.
The advanced tab is mainly for games or services which are not listed in the basic settings. Why would you want to select a port? :)
Guest Netduma_Iain
Thanks crossy
To be honest the advanced tab is for very rare use-cases. Is there any service in particular you want to filter?
I suppose this is relavant to ask here...
I'm still having quite a few issues.  If I don't select TCP/UDP for Xbox Live I get moderate nat.  If I do the geo filter doesn't work...
Thoughts?
Guest Netduma Fraser
Thoughts?
We recommend you just use the standard Xbox Live service that we provide, it should work then :)
Guest Netduma_Iain
Just to correct Fraser you should select "Xbox Live PA". Are you getting open NAT when your geo-filter is off? If so that means you NAT is open its just  false report you can safely ignore.
Just to be clear.  My router is bridged. I still have moderate NAT type.  I have open nat on xbox live, but not in game.
If you disable the Geo-filter and restart the xbox and go in game it should be open. If its open then you can reenable the Geo-filter and when moderate shows next time its just a false reading and is actually open :)
